lpezj Wed, 06/13/2007 - 06:57
  • Gold, 750 points or more
If you are going to integrate Unity with CallManager, you won't need any Voice Cards.
These voice cards are used only to communicate Unity with TDM PBXs (Avaya, Nortel, Alcatel,...).
Hope this helps,
Juan Luis
prabhusworld Wed, 06/13/2007 - 19:13
Dear Juan,
Thanks i understood. what is Cisco uOne Port, what is that? Is it Software or Hardware, what it is the application of that?
Thanks & Regards
Prabhu
lpezj Wed, 06/13/2007 - 23:06
Prabhu,
uOne is an old unify messaging system from Cisco. But that system is out of sdervice for some years.
Hope this helps,
Juan Luis
(Rate helpful posts ;-))
prabhusworld Thu, 06/14/2007 - 19:14
Dear IPezj,
Are you having any steps or procedure to intergate Unity and Call manager.
Thanks & Regards
Prabhu
prabhusworld Thu, 06/21/2007 - 19:21
Dear Sir,
I am having Cisco call manager and EPBAX which will support IP. with this can i interface both or i required any voice cards.
Thanks & Regards
Prabhu
