ASA 5520 ipsec-ra Tunnel problems
I am trying to connect to an ASA 5520 7.2(1) using Cisco VPN Client 4.8.01.0300 and it fails with:
Attempt to get Phase 1 ID data failed while constructing ID
I have attached a text document with the entire debug log of the connection.
I can provide more info, I don't want to over complicate this post if there is a quick answer for now. Thanks in advance for any help.
smalkeric Wed, 06/20/2007 - 10:51
  • Silver, 250 points or more
This error message may appers due to Tunnel group mis-configuration. also check the Cropto map command.
