TCP/UDP ports for IP Communicator and SecureCRT
Jun 13th, 2007
Does anyone knows what are the TCP/UDP ports for IP Communicator and SecureCRT?
We need those to be configured into FW.
Many thanks in advance.
Maddox
Chris Deren Wed, 06/13/2007 - 10:17
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
IPCommunicator when used as SCCP endpoint uses TCP 2000, and UDP 16384-32767 for RTP stream.
sCRT uses port based on protocol that you are attmpting to connect with, so for telnet it uses TCP 23, SSH will use port 22.
HTH,
Chris
maddox-mp Tue, 06/19/2007 - 09:29
Chris,
Thank you for your help.
That latter UDP port is going to be the issue.
Is there a way to limit that down from 16k ports?
Maddox
