slips and sec errors on our PRI
Jun 13th, 2007
I have been going back and forth with the service provider. We have a PRI handling off net calls which gets roughly 1 slip and 1 sec error every 30 seconds. This is causing echo and dropped calls. Attached is a copy of the PRI config any ideas would be greatly appreciated.
controller T1 0/0/0
framing esf
linecode b8zs
Clock source line
pri-group timeslots 1-24 service mgcp
description POTS T1
Overall Rating: 5 (1 ratings)
Chris Deren Wed, 06/13/2007 - 10:08
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Do you have the following commands on your router:
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
Chris
lfulgenzi Wed, 06/13/2007 - 10:18
  • Silver, 250 points or more
I currently see a whole slew of time slips as well, but wasn't sure it was because I was crossconnected from a 1MFT-T1/E1 on a 3845 to a 6608 port. It works and there doesn't see to be any issues.
I don't have the network-clock-select statement, but I'm wondering which one I choose and will the "ccm-manager config" statement overwrite this?
It seems like a crapshoot, i.e. no documentation, on which things are overwritten with the "ccm-manager config" statement.
I'll be eventually connecting this to a PSTN in the next few weeks and would like to fix this sooner than later.
lfulgenzi Wed, 06/13/2007 - 10:26
HA!
I'm getting a slip EVERY second....beat ya. ;)
vgw-kemptville#show controllers T1 0/0/0 brief
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20060711, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (20 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
20 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
20 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
248SHaune Wed, 06/13/2007 - 10:39
Ive tried to enter those commands both the will not work on our 2611
lfulgenzi Wed, 06/13/2007 - 10:41
They are global-config commands by the way....just in case you tried entering them on the T1 controller.
248SHaune Thu, 06/14/2007 - 07:51
Thanks Chris you where right I was trying to enter the commands on the controller. I'm going to monitor the controller and update the forum. What do these commands do?
Shaune
Chris Deren Thu, 06/14/2007 - 07:54
  • Hall of Fame,
They allow the card to partiicpate in clocking off of the network, and allow you to select the clocking priority.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008031a072.shtml
HTH, please rate all useful posts!
Chris
248SHaune Thu, 06/14/2007 - 08:07
Chris,
Since I have added the commands you requested there have been no I repeat not a single slip. I'm going to have to explain to magnt the function of the two commands and suggest the be used in future employments.
Shaune
