Clear Blocks Command
Jun 13th, 2007
I am using a Pix 525 6.3(5) and mistakenly had debugging in place for too long, while troubleshooting some issues. Doing a show blocks, shows the 256 block filled to capacity ,therefore it is not logging correctly, nor can I change the queue setting. Will a clear blocks correct the capacity issue? Also, how does this affect the firewall? Can it be done in a production environment?
Ryan
JBDanford2002 Sun, 06/17/2007 - 07:20
I believe "clear blocks" will only clear the counters. Have you tried turning logging off and back on again?
