Unity server Scheduled backup(DiRT 1.1 build 1) is not running
Jun 13th, 2007
I got a Unity4.0.(5) Server, DiRT 1.1 build 1.
Manaul backup is working properly.
Scheduled backup is not running as scheduled. ( such as 1:00am daily).
Checked the event log and services list, nothing unusual.
Anybody got any idea?
master001 Wed, 06/13/2007 - 10:45
Sorry, I missed the following error message in Event viewer.(Application log). Looks like DiRT problem, right?
Looking forward to hearing from you.
Event Source: VBRuntime
Event Category: None
Event ID: 1
Date: 6/13/2007
Time: 2:08:00 PM
User: N/A
Computer: UNITY
The VB Application identified by the event source logged this Application UnityDisasterRecoveryBACKUP: Thread ID: 3128 ,Logged: Automatic backup failed - could not write to destination path: \\xx.xx.xx.xx\UnityBackup\
(\\IP address\UnityBackup\)
master001 Wed, 06/13/2007 - 18:06
I changed destination path to local drive instead of network drive, it proceeds scheduled backup!
Anybody got any idea ?
MikeTomasko Wed, 06/13/2007 - 19:09
Try clicking "Use 'two hop" method for backing up SQL data" and then try backuping to the network drive.
Zin.Karzazi Thu, 06/14/2007 - 03:57
It s definitly a user right issue. Have seen this a couple of times, just make sure the user you are using to upload the file to the Network location can read/write to that location. Also try mapping the drive using Explorer \\Network\unity using the same user/pasword see if that works.
master001 Thu, 06/14/2007 - 04:30
I am using UnityAdmin account now. And I can read/write to that location without any errors.
The storage location has been set up as \\network ip address\unity
I use "two hop" already.
I searched this forum, found some of similiar situations. Though it seems no exact solutions,and
no feedback from the posted people.
Hope sb. could help.
master001 Thu, 06/14/2007 - 05:30
Haven't tried it yet. I checked the DiRT revision history. The version 1.1.1+ doesn't fix any issue regarding backup.
jeff.singh_2 Thu, 06/21/2007 - 06:17
we had a similar issue, we mapped to the remote drive using a local server account rather than a domain account and it started working...Jeff
master001 Thu, 06/21/2007 - 07:52
Thank you guys for sharing information.
It should be user right issue in my case.
I changed the remote drive to CallManager server local drive. The scheduled backup started working!
The remote drive is in another domain,however I can't verify user right as I can't access that domain.
I will update if I could fix the issue completely.
