VG248 Backup and restore
Jun 13th, 2007
Does anyone know if a VG248 config can be copied to a laptop and then restored ?
The VF224 is not a problem as it is similar to a router with a CLI but I cannot see a way of doing this on a VG248
Any ideas ?
umedryk Wed, 06/20/2007 - 11:45
) ftp into the vg248
2) type get user.cfg once you are in there.
3) change the name to something else when on your pc, say to olduser.cfg
Do a "more user.cfg" or "more olduser.cfg" to verify that the config has been pulled
4) ftp to the new vg248
5) type put olduser.cfg user.cfg.
Or you can Go to Diagnostics --> Show configuration and backup
lfulgenzi Wed, 06/20/2007 - 11:53
WOW! I never knew that.
Is this a supported way to backup/restore a VG248?
I also see a user.cfg.xml file. What's that for? Is that created from the cfg file on bootup?
