Trunking on ASA
Jun 13th, 2007
Hi all,
Have a question about trunking on an ASA5510. Here is my setup.
3Com switch VLAN300 = ports 5-8 and VLAN301 = ports 9-12. I have both VLANs trunked to port 13.
ASA5510 VLAN300 on ethernet0/3.300 and VLAN301 on ethernet0/3.301. Port 13 on the 3Com switch is attached to ethernet0/3 on the ASA. I assume the next step would be to trunk the two VLANs to ethernet0/3?
I tried to run the following commands:
ciscoasa(config)# interface ethernet0/3
ciscoasa(config-if)# switchport mode trunk
but i get an "Error: % Invalid input detected at '^' marker." The ^ is pointing to the switchport command. Any ideas?
Thanks for your help.
chris.lepa Wed, 06/13/2007 - 11:28
You must do this:
asa(config)#int eth0/3
asa(config)#no shut
asa(config)#int eth0/3.300
asa(config-if)#encapsulation dot1q 300
asa(config-if)#ip add
asa(config-if)#no shut
asa(config)#int eth0/3.301
asa(config)#encapsulation dot1q 301
Hope that helps. Please rate if it does.
EvolutionVI Thu, 06/14/2007 - 06:21
Hi Chris,
Thanks for the info. I tried the command "encapsulation..." but it came up with the same error.
I was doing more research and apparently the ASA will automatically trunk the physical interface if more than 1 VLAN is added on that inteface. hmm...
One more question, I'm trying to get the two VLANs to communicate with each other but i'm having difficulties... here's my config:
interface Ethernet0/1
nameif outside
security-level 0
ip address x.x.x.2 y.y.y.y
ospf cost 10
interface Ethernet0/3
no nameif
no security-level
no ip address
interface Ethernet0/3.300
vlan 300
nameif vlan-inside
security-level 90
ip address
interface Ethernet0/3.301
vlan 301
nameif vlan-public
security-level 10
ip address
access-list vlan-inside_access_in extended permit ip any
access-list vlan-public_access_in extended permit ip any
global (outside) 1 interface
global (outside) 2 x.x.x.3 netmask y,y,y,y
global (outside) 3 x.x.x.4 netmask y.y.y.y
global (vlan-inside) 3 interface
global (vlan-public) 2 interface
nat (vlan-inside) 2
nat (vlan-public) 3
access-group outside_access_in in interface outside
access-group vlan-inside_access_in in interface vlan-inside
access-group vlan-public_access_in in interface vlan-public
route outside x.x.x.1 1
I can get out to the internet on both VLANs and they are going out on the right IPs. I just can't ping or get traffic to flow between VLAN 300 to VLAN301... any ideas?
Thanks for your help in advance.
glen.grant Wed, 06/13/2007 - 12:32
Chris is correct you would need to use subinterfaces to trunk whatever vlans you want .
