ASA and SQL Server Port
Jun 13th, 2007
I've a dmz interface and outside interface that's connected to the Internet and also I've an inside interface that's connected to the inside network. My problem is that I can't connect to the dmz to the inside through the MS SQL Server 2005, I already opened the port 1433 for the sql server but no way. I need a solution for this problem because it's urgent.
Thanks in advance
acomiskey Wed, 06/13/2007 - 10:21
  • Green, 3000 points or more
"My problem is that I can't connect to the dmz to the inside"
-Do you mean to the dmz from the inside? Which way is the traffic going?
hassan_al Wed, 06/13/2007 - 21:06
The traffic is going from the inside network to the dmz and from the the inside to the dmz if no problem from the outside they can access the web site I've made and also from the inside to the dmz they can access the web site on the dmz because I've allowed the port 80 from the ASA and they can access it.My problem is that there's no connectivity between the to SQL Server (inside,dmz) I wan to make an SQL Registration from the inside to the dmz and vis versa. I hope that you get my point.
Thanks in advance
anandramapathy Wed, 06/13/2007 - 21:08
  • Bronze, 100 points or more
ensure that the packet does not get NATted from Inside to DMZ & Vice versa
have you applied the ACL on the DMZ interface.
enable DMZ ----> Inside 1433
