06-13-2007 10:57 AM - edited 03-05-2019 04:42 PM
I cannot see the 24 FE ports on the switch. Please help
Switch#sh ip interface brief
Any interface listed with OK? value "NO" does not have a valid configuration
VLAN1 unassigned NO unset up up
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
Switch#
Switch#
Switch#
Switch#sh va
Switch#sh va la
Switch#sh vlan
VLAN Name Status Ports
1 default active Gi0/1, Gi0/2
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Switch#
Switch#
Switch#
Switch#sh ver
Switch#sh version
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC17, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:04 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C3500XL boot loader
Switch uptime is 4 minutes
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC17.bin"
cisco WS-C3524-PWR-XL (PowerPC403) processor (revision 0x01) with 8192K/1024K bytes of memory.
Processor board ID CAT0613Y0YG, with hardware revision 0x00
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
24 FastEthernet/IEEE 802.3 interface(s)
--More-- 2 Gigabit Ethernet/IEEE 802.3 interface(s)
--More--
--More-- 32K bytes of flash-simulated non-volatile configuration memory.
--More-- Base ethernet MAC Address: 00:09:7C:05:9F:00
--More-- Motherboard assembly number: 73-4033-08
--More-- Power supply part number: 34-0968-02
--More-- Motherboard serial number: CAT06120AV8
--More-- Power supply serial number: LIT06121367
--More-- Model revision number: F0
--More-- Motherboard revision number: A0
--More-- Model number: WS-C3524-PWR-XL-EN
--More-- Daughterboard serial number: CAT06120937
--More-- System serial number: CAT0613Y0YG
--More-- Configuration register is 0xF
--More--
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#
06-13-2007 11:36 AM
Looks like a bad hardware. You might want to open a TAC case.
This is similar to TAC case "C811601".
HTH.
