Static translation for an inside IP
Jun 13th, 2007
Here is what I am trying to accomplish:
Any inside users going out should be dynamically translated to 192.168.2.2-200.
But for one host, 172.16.1.1, I want that to be xlated into 192.168.2.1 all the time.
I have a sample confi below. I think I do have problem with in2out4static rule because traffic initiated by 172.16.1.1 could use in2out acess list instead of in2out4static.
Are there any access-list priority?
I think access-list in PIX/ASA behave different from routers: the order of the statement doesn't matter. (I may be wrong though.)
Could somebody please help me out?
PIX Version 7.1(2)
interface Ethernet1
speed 100
duplex full
nameif inside
security-level 100
ip address 172.16.1.254 255.255.255.0
interface Ethernet2
nameif outside
security-level 10
ip address 192.168.1.254 255.255.255.0
access-list in2out extended permit ip any 10.1.1.0 255.255.255.0
access-list in2out4static extended permit ip host 172.16.1.1 10.1.1.0 255.255.255.0
access-list out2in extended permit tcp any host 192.168.2.1 eq 80
global (outside) 2 192.168.2.2-192.168.2.200 netmask 255.255.255.0
global (outside) 3 192.168.2.1
nat (inside) 2 access-list in2out
nat (inside) 3 access-list in2out4static
static (inside,outside) 192.168.2.1 172.16.1.1 netmask 255.255.255.255
access-group out2in in interface outside
route networkmd 10.1.1.0 255.255.255.0 192.168.1.253
Overall Rating: 5 (1 ratings)
acomiskey Wed, 06/13/2007 - 11:46
  • Green, 3000 points or more
You're looking for the nat order of operations...
1. nat 0 access-list
2. static NAT
3. static PAT
4. policy NAT
5. regular NAT
172.16.1.1. will be 192.168.2.1 going out because of the static.
You could do this to the in2out acl as well.
access-list in2out extended deny ip host 172.16.1.1 10.1.1.0 255.255.255.0
