CiscoWorks admin password
Jun 13th, 2007
I've just did the fresh install of CiscoWorks LMS25 yesterday on Sol9 and then I was able to login to CiscoWorks using admin login credential. This morning when I installed the patch LSM25_dec2005 and now when I try to login it doesn't like the admin pasword anymore. when I look at the install logs and line where it says
Do you want to see the passwords that were entered/randomly generated and I see the correct password there. but I still get the errr "Authentication failed. Please try again" I'm not using any other login methon on CiscoWorks.
Overall Rating: 5 (1 ratings)
yjdabear Wed, 06/13/2007 - 11:22
  • Gold, 750 points or more
An old tip posted here before:
find the file
CSCOpx\lib\classpath\com\cisco\nm\cmf\servlet\cwpass (Windows)
or
/opt/CSCOpx/lib/classpath/com/cisco/nm/cmf/servlet/cwpass (Solaris)
if you replace your admin line with this:
admin:0DPiKuNIrrVmD8IUCuw1hQxNqZc=::::F::
Your admin password will be cisco.
c-cherpillod Fri, 08/10/2007 - 00:10
Thanks for you support, I did the change and it works fine. At the end the PWD is "admin" and not 'cisco'
Best regards,
Christian
nawas Thu, 06/14/2007 - 05:12
Did the password recovery, now what do I do to change to my desired password for user admin?
David Stanford Thu, 06/14/2007 - 05:49
  • Cisco Employee,
Once you log in as admin with the recovered password go to Common Services - Server - Security - Local User Setup
Click on modify my profile in the main window and there you go
c-cherpillod Thu, 08/09/2007 - 23:28
Joe,
Thanks a lot for your support, I did a recovery password and it works fine.
Best regards,
Christian
