ISO upgrade problem
Jun 13th, 2007
hi,
i know how to upgrade ISO version.
but this never happand to me yet and on the veb did not find answers.
i have 2620XM:
IOS (tm) C2600 Software (C2600-I-M), Version 12.2(13)T5, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 29-May-03 15:16 by nmasa
Image text-base: 0x80008098, data-base: 0x80B66380
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
Router uptime is 4 minutes
System returned to ROM by reload
System image file is "flash:c2600-i-mz.122-13.T5.bin"
cisco 2620XM (MPC860P) processor (revision 0x100) with 28672K/4096K bytes of memory.
Processor board ID JAE07150892 (1905305862)
M860 processor: part number 5, mask 2
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
DIR FLASH:
Router#dir flash:
Directory of flash:/
1 -rw- 6482420 <no date> c2600-i-mz.122-13.T5.bin
16252928 bytes total (9770444 bytes free)
Router#
when i copy IOS to MY flash or try to load it via tftp i get :
%SYS-6-READ_BOOTFILE_FAIL: tftp://X.Y.Z.R/c2600-is-mz.123-3.bin File read failed -- Unknown error 0.
OR
%SYS-6-READ_BOOTFILE_FAIL: flash:c2600-i-mz.123-9.bin File read failed -- Unknown error 0.
This happend to 5 versions i tried to upload.
i used 3cdeamon and SolarWinds-TFTP-Server.exe as tftp server.
any ideas?
paolo bevilacqua Wed, 06/13/2007 - 14:57
  • Hall of Fame,
    Founding Member
this indicates the TFTP server doesn't find the requested file. Check its configuration and the directories it uses and has access to.
If you install tftp32 (search with the leading engine), it will tell you very easily into which directory the files are, and the request from the router.
lepavelcisco Wed, 06/13/2007 - 15:04
The tftp works fine because i copied the currant ios to the tftp server and successfully upload it back by "boot system tftp".
And as you can see i get the seam err msg when i copy the file directly to my flash and use "boot system flash".
all works good with the original IOS but don't work for the other versions.
any ideas?
