display name for a specific called number
Jun 13th, 2007
Dear pro,
I use the CME 4.0(2) and i need to display the name of a specific called number; for example : if i call an ip phone from my GSM i need to see my name on the ip phone.
So how can i do that.
Thank you in advance
paolo bevilacqua Wed, 06/13/2007 - 19:00
  • Hall of Fame,
    Founding Member
Where are you located ? In some countries, the name will be passed via IE in ISDN setup message.
josequiros Thu, 06/14/2007 - 08:50
hello,
The client located in Morocco. in fact, we need to enter for example a name and the number on database for ccm and when that number called our gateway we been see her name.
i hope i was clair
paolo bevilacqua Thu, 06/14/2007 - 09:06
  • Hall of Fame,
    Founding Member
if telco can provide caller-id service, you can associate numbers to names and you will see it together with the calling number on the phone screen:
telephony-service
directory entry 10 5551234 name Happy Customer
josequiros Fri, 06/15/2007 - 03:33
I did what u said but it doesn't worked.
thankx
paolo bevilacqua Fri, 06/15/2007 - 06:36
  • Hall of Fame,
    Founding Member
Does the caller-id works ? Can you see the calling number on phone ?
If no, please check caller-id configuration and service from telco.
If yes, I've tested this with CME 4.1 - IOS 12.4(11)XJ3 with ISDN and works fine, so you may want to upgrade.
