Help! PPPoE in PIX failover
Jun 13th, 2007
Hi, my internet is a IP-8 PPPoE session. Now I try to install PIX515E failover but don't know how to config. If I use fix IP there is no default gateway in PPPoE setting. Somebody can help me?
gabriel-castillo Fri, 06/15/2007 - 09:16
Hello Amigo.
one of the failover requirements is to have static ip's configured. PPPOE is a dynamic way to get ip's, therefore failover will not support this.
khary Fri, 06/15/2007 - 20:04
y.haraguchi Sun, 06/17/2007 - 16:24
Thanks you very much! Because upgrade to high version is the next project so I will ask vender to change pppoe to fixed IP. Thanks!
