Divert overide on CM 4.2 Is it Possible?
Jun 13th, 2007
Does anyone know if 4.2 has the functionality to overide a divert on an ext??
On our old pbx entering #5 before the ext number made the destination ext ring even if a divert was set up on it.
Our users are kicking off big time about this losing this feature so any help would be appreciated.
Brandon Buffin Thu, 06/14/2007 - 04:05
  • Purple, 4500 points or more
There is no built in function to override a forward setting. Here's one way to accomplish what you want.
1. If your extensions are currently 3XXX, create an additional DN on each phone of 4XXX.
2. Create a translation pattern of #53XXX and translate the called number to 4XXX.
This will allow calls to internal extensions prefixed with #5 to go to the second DN on the phone bypassing the forward setting.
Hope this helps. If so, please rate the post.
Brandon
planetmaker Thu, 06/14/2007 - 06:11
Sounds great unfortunatly 99% of our phones are single line 7911's!
Thanks anyway
