Privilege level not the same
Jun 14th, 2007
Hi all,
We have configured a user on 1 of the PIX firewall's witch privilege level 15.
When we do a "sh run" or "sh user *****" the it shows us that the configured user has a privilege level 2 instead of 15.
When I logon with the specific user and then start the command sh curpriv I get the output below:
Username : enable_15
Current privilege level : 15
Current Mode/s : P_PRIV
Can someone explain to me what is going on and if this is normal behaviour of the PIX?
Thanx in advance.
Overall Rating: 1 (1 ratings)
Optiver_admin Thu, 06/14/2007 - 01:03
Hi Sachin,
Thanks for the response, but that is not what I described. The user has still privilege level 15, but it is not visible with the described commands. Except when I login with this user, then I can se that it has privilege level 15. All the commands can be started, that is not the issue. Has anyone idees?
ahmet-saat Thu, 06/14/2007 - 05:38
Have you check the pix version u use has a bug or not?
pls rate if it helps...
