QoS on OC-48 SRP interface on 10720 router
Answered Question
Jun 14th, 2007
We have a DPT ring with 10 10720 routers on it. The ring is connected to an OC-48 SRP interface on each router.
Voice traffic enters and leaves the 10720 on a Fast Ethernet interface; incoming voice has DSCP46 marking on it, and a strict-priority queue is set up outbound on the Fast Ethernet interface.
Is it possible to apply some form of priority queueing on the SRP1/1 interface on the 10720? I have been trying to find something definite about this but so far I have failed.
Correct Answer by swaroop.potdar about 9 years 10 months ago
Router# conf t
Router(config)# interface srp 2/0
Router(config-if)# srp priority-map transmit 5
Router(config-if)# end
Please check this configuration guide, this should help you do the priority or other tasks with the SRP interface.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120limit/120s/srpapsgs.htm
HTH-Cheers,
Swaroop
Overall Rating: 5 (2 ratings)
Correct Answer
swaroop.potdar Thu, 06/14/2007 - 23:30
  • Blue, 1500 points or more
Router# conf t
HTH-Cheers,
Swaroop
is_networkteam@... Fri, 06/15/2007 - 02:14
Hi Swaroop
Many thanks for your very useful reply. I have been looking for this kind of information for a long time!
