Problem with Catalyst 2955
Jun 14th, 2007
I got a problem with my Cisco Catalyst 2955 which is connected through crossed link to a Cisco 2950 via the Gigabit port.
The 2950's gibagit port doesn't detect any connection to the 2955 when I plug a link in the 2955's gigabit port.
I try multiple configs on both sides :
Duplex Auto/full
Speed : 1000/auto
But it still does't work..
Do you have any ideas to solve that problem ?
Thanks a lot !
smothuku Thu, 06/14/2007 - 01:52
  • Silver, 250 points or more
Hi ,
First check the cross cable which you are using for connecting the switches.
If it ok then make the speed and duplex auto on both ends...
have you configured any ip addresse on gig interfaces of switches.
satish
antonenowak Thu, 06/14/2007 - 02:16
Thanks for your answer,
I put speed and duplex on both ends, I didn't configured any ip addresses on gig interfaces, should I done it ?
smothuku Thu, 06/14/2007 - 02:23
Hi ,
what is the status of gig interfaces once you connect those with cross cable.
Is the cross cable good one ?
Satish
Anand Narayana Thu, 06/14/2007 - 02:27
make sure either of the two port is error disabled automatically or administratively shutdown
antonenowak Thu, 06/14/2007 - 04:17
They are both error disabled automatically and administratively shutdown.
I don't know where is the problem..
Any over ideas ?
Thanks.
Anand Narayana Thu, 06/14/2007 - 04:22
just issue "shutdown" & then "no shutdown" your problem is solved.
antonenowak Thu, 06/14/2007 - 04:50
It doesn't work, the Gig port is still inactive..
What else can I do ?
glen.grant Thu, 06/14/2007 - 06:14
  • Purple, 4500 points or more
If this is copper try a full 8 conductor cat5 straight thru cable , remember gig uses all 4 pairs of wires to run gig . Leave the switch port settings as auto .
antonenowak Thu, 06/14/2007 - 06:44
Sorry but it doesn't work.. I'm beginning to think that the Gig ports are damaged..
