Device appear as ? in topology service
Jun 14th, 2007
I have new devices add and when i view by topology service, they appear as a green box with ? instead of the switch picture. Those device are 2960 and I already install the latest device package. These device can be view by Ciscoview correctly. I don't know why ciscowork detect them as device unknown. Please advice how to solve it.
jan
Overall Rating: 5 (1 ratings)
Martin Ermel Thu, 06/14/2007 - 02:54
  • Blue, 1500 points or more
if they are on the topo map with a question mark they also should be listed in the tree on the right side with their sysObjectID rather then the procuct name. If that is the fact your are missing the correct device package for Campus. I assume you have updated the dev pkgs only for Cisco View. To update Campus you should first check if you have the actual MDF pkg in Common Services (CiscoWorks Server) and then update Campus according to the the readme for the patch. With a CCO login you can get the updates here:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-campus
also update the other apps to get full support for the device.
