7600-sip-200 configuration doubts very urgent
Jun 14th, 2007
dear all,
i'm new to 7600-sip-200 and oc3 related configurations.
i've 2 6506-E switches one is in my office and one is 10km's away supervisor engine is Ws-SUP32-GE-3B which is installed on 5th slot of the switch IOS is 12.2 and i've 7600-SIP-200 SPA interface processor installed on 1st slot and SPA-2XOC3-POS installed in it with SFP-OC3-IR1 my requirement is i need a point to point connection between these two switches.
ihave no idea regarding this i'm new to these hardwares, basically connections will be like p-t-p connection between 2 SFP-OC3-IR1. ATM configuration is required for this? Can anybody suggest or give any sample configuration or guidance to configure these items.
Overall Rating: 3.5 (2 ratings)
binoyjosephstanly Thu, 06/14/2007 - 04:12
hello dear satish i really appreciate your post. if you can give some inputs related to our exact scenario that will be very helpful.
balajitvk Thu, 06/14/2007 - 09:31
Hi Binoy,
It may be helpful to you, Pls. find the sample POS configuration.
interface POS //
ip address x.x.x.x
no ip directed-broadcast
ip pim sparse-mode
load- interval 30
carrier-delay msec 0
crc 32
pos ais-shut
pos framing sdh
pos report rdool
pos report lais
pos report lrdi
pos report pais
pos report prdi
pos report sd-ber
pos flag s1s0 2
pos delay triggers path 0
no cdp enable
no shutdown
Rate if it does,
binoyjosephstanly Thu, 06/14/2007 - 22:05
hello friend
thanks for your input can give some more details.what will be max speed of the connectivity i can achieve, for that i need to set any speed parametrs?
no need of any ATM confurations rt?
suppose on this link if i configure and for my branch in that case it will be subnet and for my LAN im planning so in this case a route entry in my sup32 will take care of the routing rt? i need to mention only
ip route
this route entry is reqd only inside the supervisor rt is there anything i need to mention in 7600-sip-200 configuration?
please help.
Paolo Bevilacqua Thu, 06/14/2007 - 23:08
no need for configuring speed.
no need to any atm (there is no atm)
no need for static router (if you configure a routing protocol - reccommended).
binoyjosephstanly Thu, 06/14/2007 - 23:21
hello friend
thanks for your input.So this will be a HDLC configuration.
so you mean to say if the point to point link and LAN is on 2 diff networks no need of routing?
can you explain i didnt get ur 3rd point
Please reply
Paolo Bevilacqua Thu, 06/14/2007 - 23:33
probably in your organization there is already a routing protocol used, like OSPF or EIGRP.
The recommendation is to extend this configuration to these new routers.
You will avoid the need of manually entering static routes that are prone to mistakes, and need to be modified every time there is a topology change.
Good luck !
