VPN Pix 501 issue
Jun 14th, 2007
attempting to configure the following.
h - p1 - I - p2
h - host
p1 - 501 PIX (I control)
I - Internet
p2 - Cisco Device with VPN enabled.
I can VPN from home into p1 and establish connection however when behind p1 and I attempt to VPN to P2 I can establish a connection however can't pass traffic. I have PAT running on my pix (p1)
I understand that I should not have the 101 ACLs configured the way they are currently, just trying to rule out that my ACLs were not blocking.
-T-
Does the 501 allow this functionality?
acomiskey Thu, 06/14/2007 - 04:32
What device is p2? If it is a pix you need the command isakmp nat-traversal. Whatever it is needs nat-t.
tstrunce Thu, 06/14/2007 - 04:47
Unfortunately I have no control over p2, this is a customers device. I do not have a VPN tunnel connecting the two devices, I just want to be able to use the cisco client from inside p1 and connect to p2.
I am able to connect if I remove p1 and replace it with a linksys. P1 is not allowing something..I just don't know what it is.
acomiskey Thu, 06/14/2007 - 04:55
tstrunce, that is not necessarily the case. I understand you are not tunneling between the devices. Since you pix is doing pat, you must be able to do nat-traversal from you client. This means your client must be configured and the remote end point must be configured for nat-t. Your pix is not blocking anything.
Another option is to do "fixup protocol esp-ike" on your pix, this will allow for one vpn connection and one only. You will also not be able to terminate vpn's on your pix.
A one to one static on your client will help as well if you have an extra ip address.
tstrunce Thu, 06/14/2007 - 05:04
ok, I understand now..PAT is the issue.
fixup protocol esp-ike is not an option because I need users to be able to VPN in. I've seen this command before in the past, just didn't understand what it did.
How does a 1 to 1 static work? I understand that I would need another external IP address on my side however would the other IP address be the external interface on p2?
BTW...thanks so much for the response!
acomiskey Thu, 06/14/2007 - 05:10
It works like this...basically it would nat the client 192.168.1.1 to 1.1.1.1, not pat, therfore allowing you to connect.
static (inside,outside) 1.1.1.1 192.168.1.1 netmask 255.255.255.255
tstrunce Thu, 06/14/2007 - 05:18
so basically
static (inside,outside) netmask <32-bit>
which would be a specific single host surfing the internet using NAT.
acomiskey Thu, 06/14/2007 - 05:18
You could also try "isakmp nat-traversal" in your pix. I have heard this may help, but not in my experience. Make sure you have enabled transparent tunneling in your vpn client config, udp 4500.
tstrunce Thu, 06/14/2007 - 05:49
I'll give the isakmp nat-traversal a try..I wasn't aware of enabling transparent tunneling in my VPN client config, UDP 4500.
acomiskey Thu, 06/14/2007 - 05:59
I think it's usually enabled by default. Ipsec over udp on the transport tab. Can you find out if the remote site device is allowing nat-t?
tstrunce Thu, 06/14/2007 - 06:01
yes but will take some time for them to get back to me :(
calling them and waiting a call back
