4948-10GE
ariela Thu, 06/14/2007 - 05:28
  • Silver, 250 points or more
nope:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4900/4948-10ge/05modcfg.html
"The Cisco 4948-10GE switch has two ports that can be configured with modules with SC connectors, as shown in Figure 4-1. The following module types are supported:
?LR
?Other types are ro be announced soon "
the question is: "why use 4 links 1Gb each instead of 2 links 10Gb each?"
Andrea
bchaltraw Thu, 06/14/2007 - 07:47
The carrier module I believe you are thinking about is like the new E-Series 3750's. That carrier isn't available for the 4948, it's 10Gig only. You may want to check out your switch there is a bug that has been found in the early serial numbers where it will go to RMON after a reboot. The fix is to swap it out, I have 40 of them going back once I figure out how to schedule the downtimes....
