CM 4.2(1) Blocking Internal CLI
Jun 14th, 2007
I need to block the CLI for a single line internally. External isn't a problem, but how can I prevent other internal IP phones from seeing the number?
Ideally the called phone should show the name/dept of the caller, but not their number.
g.rienstra Thu, 07/24/2008 - 04:51
HI,
I want the same....Did you found a solution?
Reg
Goen
