VG248 Registering with Pub not Sub
Jun 14th, 2007
I have (another) weird one. I have 4 VG248s in use but the 4th one (installed post cutover by vendor)is not working properly. Only 3 lines will register and with Publisher not Subscriber. All other ports "register: unknown". They are all set up with dns and when I check with butt set I get reorder tone. Any ideas or suggestions? Thank you inadvance for your time.
~ Liz
PS Running CM 3.3(4)SR2
rob.huffman Thu, 06/14/2007 - 05:58
Hi Liz,
In CCM for the specified VG Port check the Device Pool and the related Callmanager Group for the registration problem.
For the ports, Console or Telnet into the VG itself and go into Configure>Telephony>Port Enable Policy>**Auto
Hope this helps!
egrinkin1 Thu, 06/14/2007 - 11:54
I checked the DP and it's the same as the 3 VG248s that are working. We only have one CM with a Pub and a Sub and no groups (not an option in 3.3?) As for the telnet session... requires a password which I don't have.
I think I'm going to have to ask my current vendor to reconfigure the password on the VG248 and check the config. I was trying to avoid it but don't see any other options. :-(
Thank you for your time!
