Route Redistribution Question
Jun 14th, 2007
Hey All,
In regards to Route Redistribution, I'd like to understand something here. In performing one-way redistribution, I have the following scenario:
A--B--C--D
Routers A & B are running Rip v2
Router C is running Rip v2 & OSPF
Router D is running OSPF
On router C I've configured the OSPF command: redistribute rip subnets metric 30. In the routing table in Router D, it displays my OSPF E2 routes correctly for all of the rip subnets. From router D I can now ping all interfaces running both Rip & OSPF - which is good. However, I cannot ping beyond router C from Router D - even though D's routing table clearly shows all of the Rip subnets across the network.
Sooo, my question is: Is this correct? I don't think it is - should I not be able to ping all of the other routers from D, since their routes are in the table? *I have verified all connectivy from all routers, and I can also ping from Router C to all interfaces on A & B. *No access lists or anything else has been configured - just the ip addresses and the routing protocols...
Edison Ortiz Thu, 06/14/2007 - 07:53
Router A and Router B need to have routing information from Router D.
The packet from router D gets there but it doesn't know how to return.
You must redistribute ospf under the RIP process or originate a default route under RIP on Router C.
bwgray Thu, 06/14/2007 - 10:00
You rock!
Many thanks. As soon as I put in a network statement of 0.0.0.0 into the ASBR for rip, it pinged!
