Catalyst 3750-12S (Fiber) and server max throughput?
Answered Question
Jun 14th, 2007
Let's say you have two mainframes which need to transfer data to each other.
If you put a fiber network adapter on such mainframes, what is the data rate that can flow through the fiber network adapter and switches ?
From the information below, is my understanding correct that the switch can handle up to 32 Gbps per port? Do you think the server network adapter could handle such traffic rate though?
Catalyst 3750G-12S (WS-C3750G-12S-S)
12 SFP-based Gigabit Ethernet ports
32-Gbps, high-speed stacking bus
Innovative stacking technology
1 rack unit (RU) stackable multilayer switch
Delivers enterprise-class intelligent services
Correct Answer by paolo bevilacqua about 10 years 1 month ago
the capacity of the BUS of the switch is 32Gbps. Per port, is the standard of 1Gbps dull-duplex.. If you need more, and if your mainframes supports that, there are switches that support 10 Gbps per port. Of course, these are noticeably more expensive.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Thu, 06/14/2007 - 06:34
  • Hall of Fame,
    Founding Member
