Cisco says it will be updates to the CCNA!!!
Jun 14th, 2007
I got an email from Cisco that on June 26th there will be an announcment on "Program Change" on the CCNA. What they will add? What they will remove?
My bet is they will remove ISDN and they will add IPv6, Wireless and maybe VPNs...
megg1ttdefence Thu, 06/14/2007 - 08:11
Hmmm.. I'm sitting ICND on the 28th June to complete (hopefully) CCNA. Not sure if I should hold off now!
Can anyone confirm this change? Cisco Moderators?
nicklehmen Fri, 06/15/2007 - 03:50
I would also like to know if this change can be confirmed. I am planning on taking the exam end of June too.
nicholas_ong Fri, 06/15/2007 - 09:32
I think there should not be any worries about changes to CCNA, especially if you had made booking for the tests. The tests should have the same coverage, if they made major overhaul as they did for CCDA, they would change the tests codes and announce retirement of the current exams.
*Please rate if helpful
