3750 error
Jun 14th, 2007
can you tell me what is the difference with following command
erase startup config
erase nvram
i run "erase startup config" after my 3750 giving error
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 3072
flashfs[0]: Bytes available: 15995904
flashfs[0]: flashfs fsck took 7 seconds.
...done Initializing Flash.
Boot Sector Filesystem (bs) installed, fsid: 3
Loading "flash:c3750-ipbase-mz.122-25.SEE2.bin"...flash:c3750-ipbase-mz.122-25.S
EE2.bin: no such file or directory
Error loading "flash:c3750-ipbase-mz.122-25.SEE2.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically. The BOOT
environment variable needs to be set to a bootable
Overall Rating: 5 (1 ratings)
Edison Ortiz Thu, 06/14/2007 - 07:13
erase startup-config and erase nvram serve identical functions.
However, the IOS listed in the bootvar is missing.
Can you post the output from typing
dir flash:
upendra07 Thu, 06/14/2007 - 07:21
erase startupconfig and erase nvram
switch: dir flash:
Directory of flash:/
2 -rwx 1456 config.text
3 -rwx 5 private-config.text
15995904 bytes available (3072 bytes used)
Edison Ortiz Fri, 06/15/2007 - 14:43
Your IOS is missing. You must download a copy from Cisco and tftp to flash:
As I stated before, the commands
erase nvram
perform the same task of erasing your startup config.
It seems you executed other commands and deleted the operating system from flash.
Richard Burts Thu, 06/14/2007 - 07:17
I am not sure what is going on here. But the messages that you post sound more like flash was erased than that startup-config was erased. The messages that mention:
sound like there is a startup config and that it has a boot system command pointing to this image file and it appears that there is not any valid image file in flash. These messages in particular suggest that there is no image in flash:
royalblues Thu, 06/14/2007 - 12:10
The erase nvram: command replaced the write erase command and the erase startup-config command.
But as indicated by Rick, there doesn't seem to be an IOS present in the flash for successful bootup.
HTH, rate if it does
upendra07 Sat, 06/16/2007 - 09:37
I solved the problem. I copied image from tftp and it's working fine.
