MGCP command..
Jun 14th, 2007
I've been trying to research the "mgcp rtp unreachable timeout command". Although there is plenty of information about this command I have been unable to find out what an "action notify" suffix means. Does anyone know?
Justin
Overall Rating: 4 (1 ratings)
Aaron Harrison Thu, 06/14/2007 - 08:04
  • Community Spotlight Award,
    Member's Choice, May 2015
Hi Justin
A notify (NTFY) message in MGCP terms is sent from the gateway to the call-agent (CallManager in this case).
So the command will set the gateway to notify CallManager in the event that an rtp stream starts getting unreachables (which suggests the other end is no longer accessibly so the call should be terminated).
Aaron
Please rate helpful posts..
jmachiggins Thu, 06/14/2007 - 08:27
OK. So this just tells the gateway to tell CallManager that the call failed. I could not find an explination anywhere. Thanks.
Justin
