Pinging Between Switches
Jun 14th, 2007
Hi Everyone,
I have two switches connected to eachother, the access link runs over VLAN 170. If I have an IP address on one switch on int VLAN 170 and an IP address on the other switch (from the same sunbet) but on int VLAN 2, should they be able to ping each other?
Reason is, I have only VLAN 170 on one switch so I cannot have a L3 interface for VLAN 2.
Any ideas?
Cheers,
Dan
Jagdeep Gambhir Thu, 06/14/2007 - 09:33
Dan,
It should not ping but I have seen some cases where it was able to ping. This is caused due to vlan bleeding.
Jagdeep
Jon Marshall Fri, 06/15/2007 - 01:58
Dan
If is the same subnet is there any reason why you use different vlans on the 2 switches.
You could make the link between the 2 switches a trunk and then reallocate the vlan 2 port to be in vlan 170.
Jon
balajitvk Fri, 06/15/2007 - 06:43
Hi Daniel,
Eventhough it is not recommanded to have two side of one access link in two different vlans, it will work, but only it will generate CDP Warnings i.e. vlan mismatch.... which you can avoid by disabling cdp on those ports.
Hope it clarifies your doubt.
Rate if it does,
Rgs
farkascsgy Mon, 06/18/2007 - 04:55
Of course you can ping. If the two switches are connected each other using access link and not trunk you are able to ping from host which is on vlan 170 to host whis is on vlan 2 on the other. Reason: access link don't care with VLAN numbers, only trunk link do that, in access mode there is no tagged frame.
bye
FCS
Please rate me if I helped.
srue Mon, 06/18/2007 - 05:43
farkascsgy got it right...and yes, cdp will give warnings about VLAN / VTP domain mismatches.
farkascsgy Mon, 06/18/2007 - 06:47
Yes, but there is no sense to setup the same VTP domain on both switches, since access link is used between them. In this case I think there is no such error messages - but I can't recall exactly.
bye
FCS
