IPCC Enterprise-Agent Call Transferr
Jun 14th, 2007
Does anyone know if there is a way in IPCC enterprise to determine if agents are using the desktop application or their desk phone to transfer calls?
We are looking for a way to spot check if agents are following procedures.
Chris Deren Thu, 06/14/2007 - 08:16
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Well, you cannot diffriencite these, but all transfered calls show up on the webiew agent reports.
HTH, please rate all useful posts!
Chris
daviblai Thu, 06/21/2007 - 12:31
  • Cisco Employee,
The information you seek would probably be in the CAD logs which are located on the server at C:\Program Files\Cisco\Desktop\log.
We will need to use the DUMPLOG program to extract the log data.
