pick-up option
Overall Rating: 5 (1 ratings)
bhatok Thu, 06/14/2007 - 09:20
Unfortunatley, if there is a line appearance that is ringing and the handset is lifted it will automatically answer that line. If the user would like to place a phone call while another line is ringing, you must instruct them to first press the button for their primary line, then dial the number. This will take their primary line off hook and let the other line continue to ring.
Brandon
Rob Huffman Thu, 06/14/2007 - 09:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Carlos,
There is a setting in CCM that dictates this behaviour called Always use Prime Line;
In order to change this parameter, log in to the Cisco CallManager Administration page and perform these steps:
From the Service menu, choose Service Parameters.
Choose Publisher CallManager Server > Cisco CallManager service.
Under the Clusterwide Parameters (Device - Phone) section, scroll down to the Always Use Prime Line parameter, choose True for this parameter, and click Update.
Note: The default value for the Always Use Prime Line parameter is False. If the flag is set to True, when the phone goes off-hook or the speaker button is pressed, then the primary line is chosen and becomes the active line. If a call comes in on the second line of a user, going off-hook makes only the first line active. In this case, the user must select the second line in order to answer the call. If the flag is set to False, the phone automatically chooses a line as the active line based on the line status.
From this doc;
http://www.cisco.com/en/US/products/hw/phones/ps379/products_qanda_item09186a00800a6763.shtml#q39
Hope this helps!
Rob
