Does WS-4013 support PoE?
Jun 14th, 2007
I have a 4506 with a it able to support PoE? I also only have 2 1000w power supplies. I don't think the power supplies will work but don't know about the sup.
burleyman Thu, 06/14/2007 - 09:58
I did know about the line card. I was looking to see if WS-4013....not WS-4013+ would support it. Also I was just clairifying if the 1000w power supplies were ok....I don't think they are....but just wanted to check.
royalblues Thu, 06/14/2007 - 11:50
The 1000W power supplies are Data only power supplies and hence i think you would require to upgrade your power system to support PoE.
Use the power calculator to check the power requirements
HTH, rate if it does
