CME: How to have more than 15 voice translation-rules
olighec
I am running a CME system on a 2821 router, and I use voice translation-rules to translate DID numbers to inside extensions.
Here is how we do it now:
voice translation-rule 1
rule 1 /2424020/ /200/
rule 2 /4621113/ /203/
rule 3 /4621124/ /201/
rule 4 /4621140/ /202/
rule 5 /2424021/ /204/
rule 6 /2424022/ /205/
rule 7 /4621126/ /207/
rule 8 /4621130/ /206/
rule 9 /2424003/ /208/
rule 10 /2424004/ /209/
rule 11 /4621118/ /210/
rule 12 /6245146/ /300/
rule 13 /4621144/ /301/
rule 14 /4621125/ /302/
rule 15 /4621131/ /303/
voice translation-rule 2
rule 1 /200/ /2424020/
rule 2 /201/ /4621124/
rule 3 /202/ /4621140/
rule 4 /203/ /4621113/
rule 5 /204/ /2424021/
rule 6 /205/ /2424022/
rule 7 /206/ /4621130/
rule 8 /207/ /4621126/
rule 9 /208/ /2424003/
rule 10 /209/ /2424004/
rule 11 /210/ /4621118/
rule 12 /3../ /6245146/
rule 13 /2../ /2327888/
voice translation-profile translate-incoming-did
translate called 1
voice translation-profile translate-outgoing-did
translate calling 2
My problem is, only 15 rules are allowed, and I need to add more. How can I accomplish this?
Can I add a new translation-rule and add it to the "translate called" statement?
Chris
6 Replies 6
Chris Deren
My suggestion is to use num-exp instead.
Chris
I'm not familiar with that command. I'll research it. thanks
num-exp expands one number to another.
num-exp 4000 9728284000 will translate 4000 to 9728284000.
Remember that num-exp is global to the router and not specific to a dial-peer unlike translation rules and profiles.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I'm reading a little about it in the IOS command reference.
What I am unclear on is, would it work both ways?
i.e. Extension 200 has a DID number 2424020, so when you dial 2424020 extension 200 should ring, and when you dial out from 200, it should send 2424020 as caller-id.
But, some lines I want to be able to DID, but don't want them to send their number as caller-id when dialed out from. For example, extension 301 should ring when 4621144 is dialed, but I want it to send 6245146 when dialed out from.
Would that be possible?
tpetersn
Chris,
I don't mean to poach off of your issue, but can you possibly post how you are calling your translation profiles from you dial-peers or voice-ports for the incoming calls? I can't seem to get the commands correct for a T1, I can only find them for a PRI.
Thanks a bunch,
Todd
You can translate either at line or DP level.
For the first, place "voice translation-profile" command under voice-port. For the second, place it on the incoming DP.
