Logging configure terminal
Jun 14th, 2007
Hello, for a project I need to log to syslog when a user logging in through TACACS enters Configuration Terminal mode, thanks
running cisco 2800 series router
with IOS 12.4(13r)T
anandramapathy Thu, 06/14/2007 - 23:25
The command
aaa accounting exec default start-stop group tacacs+
will log all conf t requests directly to the Tacacs server
Try the following commands -
logging host ( sys log Ip )
logging trap informational
else try this command also
logging facility user
Richard Burts Fri, 06/15/2007 - 06:29
Actually the command aaa accounting exec default start-stop group tacacs+ will send accounting records for creation of exec process (when users log on) but will not send accounting records for config t. If you want to create accounting records for config t, you will need this command aaa accounting commands 15 default start-stop group tacacs+.
Jeff
Note that these send accounting records to a TACACS server not to syslog. Your original post indicated that you need to send them to syslog. I am not aware of any way to log to syslog when someone enters the config t command. Would reports from the TACACS server be an acceptable substitute?
Rick
