ASA 5505 Licence Question
Jun 14th, 2007
  • Bronze, 100 points or more
I just bought an ASA 5505 (ASA5505-BUN-K9)
I can only have 10 Inside hosts if I do a "show version" and the DMZ's are MAX 3, DMZ Restricted...
Now I want to have unlimited Inside hosts and I know I have to buy this licence:
ASA5505-SW-10-UL
Now does this also makes it available that I can use more VLAN's?
Or do I need another software upgrade to use more then 3 VLAN's?
I-1
Overall Rating: 5 (1 ratings)
anandramapathy Thu, 06/14/2007 - 23:09
HTH - Please Rate all usefule Posts
Upgrade is available for DMZ & VLANs with Cisco ASA 5505 Security Plus license
In routed mode, you can configure up to three active VLANs with the Base license, and up to 20 active VLANs with the Security Plus license.
Refer Link
http://www.cisco.com/en/US/products/ps6120/products_configuration_guide_chapter09186a0080636f89.html#wp1056883
IWAN HOOGENDOORN Thu, 06/14/2007 - 23:26
Does the Security Plus Licence also provide Unlimited Users?
Or do I need to have 2 seperate licences for - DMZ support and Unlimited User support?
anandramapathy Thu, 06/14/2007 - 23:31
http://www.cisco.com/en/US/products/ps6120/prod_brochure0900aecd80402e36.html
Cisco ASA 5505 Security Plus bundle
Includes Cisco ASA 5505, unlimited users, 8-port Fast Ethernet switch, stateful firewall, 25 IPsec VPN peers, 2 SSL VPN peers, stateless Active/Standby high availability, dual ISP support, DMZ support, 3DES/AES license, and 1 expansion slot
HTH - Please rate all use ful posts
anandramapathy Fri, 06/15/2007 - 18:51
Hope your issue is clarified.
Please rate all useful posts
