counting the number of AP's
Jun 14th, 2007
We have a large deployment of the 1242 AP's and I was wondering if there's a way of determining the exact number, short of counting them off of the controllers on the WCS?
thanks.
echelon360 Thu, 06/14/2007 - 22:38
i would imagine that running the below mentioned cli command on the controller would help.
"show ap summary"
It would tabulate the Number of APs
dbentley Fri, 06/15/2007 - 04:29
on your WCS goto Reports
Access Point Reports
Select new from the drop down menu.
Under General Tab add a name and leave everything default
Run the report
Export to CSV
Open with Excel
Just look at the row count
This is how I do it. It will give the count of all APs on all controller within your WCS
-Doug
rupert.wever Sat, 06/16/2007 - 12:02
WCS 4.1 gives you a good AP count.
Reports > Inventory Reports > Access Points
One of my customers was atually shocked to learn that they had non-LWAPP AP's lingering after running this report. What's nice is that it breaks it down by AP type.
