ASA Http-map
Jun 14th, 2007
I was trying to add peer 2 peer blocking on our ASA 5100 (7.2.2) using the HTTP-Map command. The ASA responded saying that command has been depreciated. It said I should use a policy map command instead. I looked at the 7.2 command reference but, I didn't see anything new under the policy map section. What the new command? Thanks for your help.
