Ip sla, monitor multiple host, is this possible ?
Jun 14th, 2007
Hy Guys, have you never tried to use ip sla to monitor multiple host inside a single object ?
I'd like to use sla to monitor two different host on two different interface so if one of this host is down, i'm able to switch router using HSRP.
I didn't find any info about how to configure tracking multiple host (for example with icmp) with a single object (i must use a single object, because i can link only one to HSRP). Is this possible ?
ariela Thu, 06/14/2007 - 13:24
  • Silver, 250 points or more
Hi Max,
nice to hear you ;)
Well, I think it's possible, see that:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080441847.html
another good point to investigate:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080457bcc.html
I think you could create more operations, then schedule those with a "group schedule".
Andrea
