Gateway Utilization Reports Blank
Jun 14th, 2007
Can you run Gateway Utilization Reports on a MGCP IOS based gateway on a Cisco 3845? When I run them, the reports come back blank. I can run reports for phones and phone numbers and they have data. But no data on the gateways. Thanks!
q-conklin Fri, 06/15/2007 - 13:16
Have you gone to CDR > System > Sys Parameters > Gateway Config... and entered the info there? I believe this is a pre-req
MikeTomasko Fri, 06/15/2007 - 13:22
I just added the area code in for the PRIs. I'll give it a day or two and check it again. We'll see if that works. Thanks!
