Multicast over different subnets
Jun 14th, 2007
I have a need to do multicast over different subnets and across several LAN routers. I can see all interfaces and vlans associated to the group that are connected directly to the local router,but can't get the remote routers to join. I think I should be using ip mroute but not sure.We are doing this on 3750 switches running eigrp.
Any ideas welcome
Thanks Chris
Overall Rating: 4 (1 ratings)
drolemc Thu, 06/21/2007 - 12:25
Router(config)# interface virtual-interface
Defines a virtual interface for multicast fast switching. Routers joining the same session must have their virtual interfaces on different subnets. Otherwise packets are not switched to the IP network.
Router(config-if)# ip address address subnet-mask
Assigns the IP address and subnet mask for the virtual interface.
Router(config-if)# ip pim { sparse mode | dense-mode | sparse-dense-mode }
Specifies Protocol Independent Multicast (PIM). Whatever mode you choose should match all the interfaces in all the routers of your network.
