Aaron Harrison Fri, 06/15/2007 - 04:31
  • Community Spotlight Award,
    Member's Choice, May 2015
You set the switchports (depending on hardware and software versions) like so:
mls qos trust dscp (to use DSCP to classify)
mls qos trust cos (to trust CoS)
If you have the port set up to conditionally trust the cisco-phone, then it uses CoS and can optionally instruct the phone to mark down PC-port traffic.
Aaron
Please rate helpful posts...
Steven Holl Tue, 06/19/2007 - 13:34
  • Cisco Employee,
L2 switchports won't look at DSCP values since DSCP is a L3 header. CoS tags are only carried through on trunk links. L3 switchports won't trust DSCP, and you need to trust it with the 'mls qos trust' commands recommended above.
