Switch - Trunk problem or Hardware Failure
Jun 14th, 2007
Hi NetPro,
this switch keep rebooting especially at mid night any idea ?
00:01:15: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Mar 1 00:01:17.663: %SYS-5-CONFIG_I: Configured from memory by console
*Mar 1 00:01:18.508: %SW_VLAN-4-VTP_INTERNAL_ERROR: VLAN manager received an internal error 14 from vtp function vtp_download_info: Bad parent VLAN ID
-Traceback= 3D7610 3D3760 1E7544 1EAB70
*Mar 1 00:01:19.228: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software
IOS (tm) C3550 Software (C3550-I5Q3L2-M), Version 12.1(22)EA5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 13-Jul-05 23:51 by antonino
*Mar 1 00:01:19.228: %SNMP-5-COLDSTART: SNMP agent on host MY-MKZ-c35-Log-3-d2 is undergoing a cold start
2007-06-15 01:25:42 Local7.Notice 172.17.0.2 2007 Jun 15 01:17:12 GMT8 +08:00 %DTP-5-NONTRUNKPORTON:Port 3/7 has become non-trunk
2007-06-15 01:27:50 Local7.Notice 172.17.0.2 2007 Jun 15 01:19:20 GMT8 +08:00 %DTP-5-TRUNKPORTON:Port 3/7 has become isl trunk
regards,
Jackal
glen.grant Fri, 06/15/2007 - 10:10
  • Purple, 4500 points or more
Looks like a bug of some type , might want to upgrade the code as that is pretty old now and work from there .
ney25 Sun, 06/17/2007 - 18:01
Hi Glen,
so, you meant upgrade IOS to newer version ?
beside upgrade, any ideas ?
regards,
Jackal
