Problem router 2621xm
Answered Question
Jun 14th, 2007
Dea All,
Now i had the problem, could you help me?
1- i had router 2621xm:After i configure int f0/0 than no shut it show message like this:
Router(config)#int f0/0
Router(config-if)#ip add 10.10.10.1 255.255.255.0
Router(config-if)#no shut
*Mar 1 00:00:59.625: %AMDP2_FE-1-INITFAIL: CSR0=0x0000
Router(config)#
by the way on router 2621xm had 2 fastethernet but my router i can see one interface is fastethernet 0/0.
What's going on?
Best Regards,
Join
Correct Answer by Richard Burts about 10 years 1 month ago
Join
It sounds like a hardware problem. Probably the best thing would be to open a case with Cisco TAC.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Thu, 06/14/2007 - 18:47
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Join
Rick
join_sn09 Thu, 06/14/2007 - 19:45
Dear Rick,
Thank you for your reply.
Best Regards,
Join
