Help>ICMP Echo Request
Jun 14th, 2007
Ping sample:
Reply from bytes=32 time=1672ms TTL=253
I'd like to know what is the possible reason when im conducting ping to the ip indicated above im geting high value of time(ms).
Note: It's an IP address of a switch in Vlan 80.
mohammedmahmoud Thu, 06/14/2007 - 21:52
High delay values in LANs, is most probably due to cabling issues, duplex issues, broadcast storms, LAN devices performance issues, can you tell us more about your connectivity schema.
Mohammed Mahmoud.
guruprasadr Fri, 06/15/2007 - 02:32
Pls try with the Traceroute to this IP inorder to verify the Route it takes from Source to Destination.
I could also be an Routing Issue. Also, Check the VLAN Status, Port Status, Speed & Duplex Status, etc.,
Pls Rate if Helps
Best Regards,
Guru Prasad R
