Alarm indiation in E1 Card
Jun 14th, 2007
I can see the ALM and CD alarms in my E1 card, i have specified the card type, my card is working fine as i have check with 1245 physical loop also. what is the CD alarm refer to....
Paolo Bevilacqua Thu, 06/14/2007 - 23:04
Do "show controllers E1" and you will see what the alarms are. Usually, no signal, that means, bad cabling, or faulty circuit.
pciaccio Fri, 06/15/2007 - 02:16
The CD alarm is the CARRIER DETECT alarm. It means you are not seeing the remote end from a layer one prospective. Do you have a RED Alarm on the line? You probably have a line issue or cabling issue....
