Classification of calls
Jun 15th, 2007
Is it possible in IPCCX that a agent can classify a call himself if it is an order or a reclamation and that this classification can be used for reporting purposes?
Best regards
Peter
muhammmad.rehan Tue, 06/19/2007 - 04:25
IPCCX comes up with the out of the box options, if you can classify call at the Queue level, i mean in the scripts then it would be give you better reports.
Muhammad Rehan
