CME Call forward All Issue
alvin1976
Hello all, I've configured CME4.1 in a 2851 with CUE 2.3. I'm facing some issues with call forwards. Here's the scenario:
Call-forward-All configured on IP Phone A to a external landline or handphone number-
a) IP Phone B calling IP Phone A, call forward works. Land line or handphone receives call.
b)External handphone call DID of IP Phone A. Calling phone can hear ring tone, but the landline/handphone which was forwarded to from IP Phone A is not ringing. After a while, the ringing tone on the calling phone stops and we get slow engage tones which is not our usual telco engage tone in S'pore.
If the targeted call-forward-all number is configured as an internal extension of another IP Phone, everything works fine.
Here's the configuration in the attached file.
Any idea what the issue is?
Alvin
Alvin,
my bad. I had you modify the calling number plan/type, but left the called number plan/type (that is even more important), unchanged.
You can do that in three ways, pick the one you like better:
- under interface e0/0/0:15, "isdn map address ... type unknown"
or, under the outgoing DP, "numbering-type unknown"
or, a translation-rule outgoing for called, matching everything like: // // type any unknown. You can apply it either at DP or voice-port level.
Let us know if it works!
9 Replies 9
paolo bevilacqua
Hello Alvin,
This can be an issue with Q931 messages and IE on the PRI. Now, you have configured:
voice call send-alert
voice call convert-discpi-to-prog
voice rtp send-recv
Did you configured these because of a problem, or just because these commands are in some troubleshooting document ?
I need to ask this before be proceed further with the usual debug of "isdn q931".
you got me there, i've no idea this came into the config. probably configured by fellow colleagues when they are troubleshooting other issues. meanwhile here's the debug isdn q931:
132350: Jun 15 17:08:15.793 SGT: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0034
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98382
Exclusive, Channel 2
Calling Party Number i = 0x4183, '96800021'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xC1, '63057340'
132351: Jun 15 17:08:15.809 SGT: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8034
132352: Jun 15 17:08:15.817 SGT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1
, Calling num 63057373
132353: Jun 15 17:08:15.817 SGT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1
, Called num 90298053
132354: Jun 15 17:08:15.817 SGT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x098C
Sending Complete
Standard = CCITT
Channel ID i = 0xA9839C
Exclusive, Channel 28
Calling Party Number i = 0x4183, '63057373'
Called Party Number i = 0xC1, '90298053'
132355: Jun 15 17:08:16.145 SGT: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x898C
132356: Jun 15 17:08:16.545 SGT: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x898C
Cause i = 0x829C - Invalid number format (incomplete number)
Progress Ind i = 0x8288 - In-band info or appropriate now available
132357: Jun 15 17:08:16.549 SGT: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpon
e sending RELEASE for callid 0x890D
132358: Jun 15 17:08:16.553 SGT: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8 callref = 0x8034
Progress Ind i = 0x8188 - In-band info or appropriate now available
132359: Jun 15 17:08:20.745 SGT: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x0034
Cause i = 0x8090 - Normal call clearing
132360: Jun 15 17:08:20.749 SGT: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x8034
132361: Jun 15 17:08:20.753 SGT: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x098C
132362: Jun 15 17:08:20.833 SGT: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x0034
132363: Jun 15 17:08:20.873 SGT: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x898C
Oh yeah, you've probably noticed that my outbound calling number has been translated to my PRI trunk number 63057373.
The problem appears to be:
Cause i = 0x829C - Invalid number format(incomplete number)
Please make a call with debug to 90298053, either directly or via the forwarded extension, so we can compare the difference in the way router is building the setup message.
The translation you applied is correct. There is a technique to make so the calling number is the DID of the extension forwarding, but beside you may not want this, it's a bit more complicated.
OK, I've done the debug again, this time calling the number directly from the phone configured with the call-forward-all function.
132505: Jun 15 18:01:12.997 SGT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1
, Calling num 63057340
132506: Jun 15 18:01:13.001 SGT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1
132507: Jun 15 18:01:13.001 SGT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x09CE
Sending Complete
Standard = CCITT
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0180, '63057340'
Plan:ISDN, Type:Unknown
Called Party Number i = 0x81, '90298053'
132508: Jun 15 18:01:13.325 SGT: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x89CE
132509: Jun 15 18:01:17.405 SGT: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8 callref = 0x89CE
132510: Jun 15 18:01:20.137 SGT: ISDN Se0/0/0:15 Q931: RX <- CONNECT pd = 8 callref = 0x89CE
Date/Time i = 0x07060F1201
132511: Jun 15 18:01:20.137 SGT: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 90298053 N/A
132512: Jun 15 18:01:20.141 SGT: ISDN Se0/0/0:15 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x09CE
132513: Jun 15 18:01:22.017 SGT: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x89CE
132514: Jun 15 18:01:22.017 SGT: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27 disconnected from 90298053 , call lasted 1 seconds
132515: Jun 15 18:01:22.017 SGT: ISDN Se0/0/0:15 Q931: call_disc: PI received in disconnect; Postpone sending RELEASE for callid 0x894F
132516: Jun 15 18:01:28.225 SGT: ISDN Se0/0/0:15 Q931: RX <- PROGRESS pd = 8 callref = 0x89CD
Progress Ind i = 0x8482 - Destination address is non-ISDN
Progress Ind i = 0x8488 - In-band info or appropriate now available
Ok, the router is copying plan/type for outgoing as received on incoming. But, type "subscriber" is not accepted.
Try making your voice translation-rule 30 as:
rule 1 /^1\(73[4-9][0-9]\)/ /6305\1/ type any unknown
rule 2 /.*/ /63057373/ type any unknown
I also think you do not need the three "voice"commands above mentioned, but that's another issue.
Let us know if it works and do not forget to rate useful posts!
hi, thanks for your advise, but still no luck.. I've removed the 3 configurations as you have pointed as well as amended the translation pattern..oh yeah after removing the 3 lines, instead of getting a ringing tone, this time it is just a Telco engage tone. my debug of isdn q931 still shows similar results:
132637: Jun 15 22:44:26.488 SGT: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callr
ef = 0x0048
Sending Complete
Standard = CCITT
Channel ID i = 0xA9839D
Exclusive, Channel 29
Calling Party Number i = 0x4183, '90298053'
High Layer Compat i = 0x9181
132638: Jun 15 22:44:26.500 SGT: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8048
132639: Jun 15 22:44:26.508 SGT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x0 0x1, Calling num 63057373
132640: Jun 15 22:44:26.508 SGT: ISDN Se0/0/0:15 Q931: Applying typeplan for sw-type 0x12 is 0x4 0x1, Called num 90298053
132641: Jun 15 22:44:26.508 SGT: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0A08
Sending Complete
Standard = CCITT
Channel ID i = 0xA9839F
Exclusive, Channel 31
Calling Party Number i = 0x0183, '63057373'
132642: Jun 15 22:44:26.840 SGT: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8 callref = 0x8A08
132643: Jun 15 22:44:27.244 SGT: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8 callref = 0x8A08
132644: Jun 15 22:44:27.244 SGT: ISDN Se0/0/0:15 Q931: call_disc: PI received in
disconnect; Postpone sending RELEASE for callid 0x8989
132645: Jun 15 22:44:27.272 SGT: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8048
132646: Jun 15 22:44:27.412 SGT: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0048
Cause i = 0x82E31E - Information element not implemented
132647: Jun 15 22:44:27.412 SGT: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8048
132648: Jun 15 22:44:27.420 SGT: ISDN Se0/0/0:15 Q931: TX -> RELEASE pd = 8 callref = 0x0A08
132649: Jun 15 22:44:27.512 SGT: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8A08
Alvin,
It's working! The help is greatly appreciated! am I right to assume that when you set the numbering-type to any unknown, you are in fact specifying a wildcard to match any type of offered and presented numbering-type?
Also, here's what is another task for me relating to this. I've removed the 2nd rule of the voice translation hoping that when handphone A calls the DID of IP Phone, as it redirects to another Handphone B, handphone B will be able to see the calling number as the call-forwarding IP Phone DID. I do think my Telco prevents the CME from forwarding the original calling number of Handphone A to be shown in Handphone B. That's why i'm seeing the trunk number as the calling number. Any fantastic ways to send the caller-id of the IP Phone to the forwarded number?
Glad to know it worked. The "numbering-type" under DP will simply set the desired type for all and any call going out that DP.
Now for your other question, you are correct that is not possible to present the original calling number, because it does not belong to the numbers assigned to you by telco.
And yes, there is a fantastic way to send instead the DID of the ephone-DN on which the call-forwarding has been set. This uses the little-know loopback-dn feature. See:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dde396e/11#selected_message
Beside the solution that I gave, you will find some more in-depth discussion with Marco Pizzi that is another CME hardcore adept.
Thanks for the nice rating and good luck!
