3750 problem with numbering
Jun 15th, 2007
I changed the numner on a 3750 switch from 5 to 1 and made a reload. After this if i do a "sh ?nt status" it looks OK, but if I do a "sh run" I can see both the old numbering an the new one. 2 sets of ports. Is there anyone who has experienced this problem an have a solution for this?
Anand Narayana Fri, 06/15/2007 - 03:00
i am not clear with your question, explain me what exactly your facing the problem.
mawe008 Fri, 06/15/2007 - 03:26
When i do a "sh run" i can see 2 sets of switchports. Both the old one and the new one. When i do a "sh int statu" I can only see the new number. I use the command "switch 2 renumber 1" to change the number.
mawe008 Fri, 06/15/2007 - 03:25
Anand Narayana Fri, 06/15/2007 - 03:53
juz issue "no switch 2 provision ws-c3750-48ts" ur probz will b solved, make sure that u hav restarted the switch after issuing this command.
